gltf loading(or export?) error
Home Forums General Questions gltf loading(or export?) error
  • #61390
    omejar
    When I use the exported file (either gltf or gltf+bin), browsing the model from the application management interface shows all black.
    But when I use “sneak peek” to preview the model, it is normal.
    So now I can only work normally by copying the generated gltf and bin files from Use\AppData\Local\Temp\verge3d_tmp_…\preview after each quick preview for normal learning
    #61393
    omejar
    I noticed that the bin files of the two different ways are the same, the difference is the content of gltf.
    #61394
    What .gltf exporter do you use?
    #61395
    omejar
    <font _mstmutation=”1″ _msttexthash=”46212049″ _msthash=”87″>您使用哪个 .gltf 导出器?</font>
    oh…no…
    I’m so stupid…It’s working fine, thanks a lot
