gltf export error in 3ds 2021 v3d 4.1.1
Home Forums Bug Reports and Feature Requests gltf export error in 3ds 2021 v3d 4.1.1
  • #55378
    vklein
    Getting “Runtime error: Unknown exception thrown during executing script” in verge3d.ms line 928 at >>>:
    if hasInitiated and debug then (
    format “V3D-INFO: Reloading Verge3D modules\n”
    — COMPAT: < 2021
    >>> python.Execute (“if sys.version_info[0] > 2:
    import importlib
    else:
    out-commenting throws another “Unknown exception” later
    switching back to 4.0.1 where it worked
    Now 4.0.1 isn’t working for the project, ARGHHHHHHHHHHHHHHHHHH I’m dooooooooooomed
    Ok one project is throwing exceptions not all. This project export worked a few days ago with 4.0.1 and same 3dsmax fine. After V3d 4.1.1 install and going back to 4.0.1 broken.
    Have found the culpit: it’s a look at camera constrained 3D button in the 3d scene causing the exceptions in 4.01 and 4.1.1 hich I just copied from another v3d 3.8 working project.
    #55391
    Hi, it’s not clear from the first glance why a constraint causes such issues. Can you attach a scene file to reproduce that?
