[ GLIFTEK ] Plugin Pack: OBJECT MANAGEMENT
Home Forums Plugins [ GLIFTEK ] Plugin Pack: OBJECT MANAGEMENT
Viewing 15 posts - 1 through 15 (of 15 total)
  • #46746
    GLiFTeK
    The [ OBJECT MANAGEMENT ] Plugin Pack: Cloning objects in Verge3D is available using the clone puzzle. However, creating deep copies of objects and their corresponding materials and textures has not been available as an option. These plugins allow for detailed reproductions of individual objects or groups of objects, each with unique properties.
    This suite of plugins spans a wide range of capabilities. From Copying objects, to renaming materials, to adding and removing objects to and from groups of objects, GliffTek has you covered for all your object management needs!
    The plugin blocks included are:
    • Copy Objects
    • Copy Object
    • Rename Object
    • Set Object Selectability
    • Get Parent
    • Get Object By Name
    • Copy Material
    • Rename Material
    • Set Material Transparency
    • Create Group
    • Add Or Remove Objects In Group
    • Get Groups From Object
    • Get Group By Name
    • Get All Object Copies
    • Get All Object Copies Groups
    *All [ GLIFTEK ] Plugin Packs come supplied with a Verge3D example application, showing the plugins in action in the puzzle editor with instructional tips!
    link to – Live DEMO with Full Product Documentation!
    Purchase this powerful plugin at the Gliftek Store NOW!
    :good:
    #46747
    that is a powerful plugin! :good: :good: :good:
    #46748
    GLiFTeK
    Indeed!
    …long time coming!
    These were the very first plug-ins I began working on almost a year ago!
    :good:
    #46752
    Tremendous! Feel free to share this plugin on Reddit and add to this Wiki page (feel free to make any category you need).
    X | FB | LinkedIn
    #46755
    Plug-in is well needed for delivering light installs.
    #46764
    GLiFTeK
    If you mean by creating dynamic multiples of objects at runtime instead of loading separate objects, then very much YES.
    :good:
    #52178
    solid
    Good afternoon.
    bought your plugins
    GLIFTEK_Plugins_Helpers
    GLIFTEK_Plugins_Objects
    rescheduled
    files in /verge3d_blender/puzzles/plugins
    3D scenes in /verge3d_blender/applications
    The following changes and errors have appeared:
    Updated v3d.legacy.js
    Exported gltf
    The camera is offset from the viewpoint (did the file change relative to the already exported scene?)
    There is no node connection of the world, and as I understand it, because of this, the NEXT material is not visible.
    Exported gltf
    Before the v3d.js update
    Here the xml file is shown immediately without the sidebar of the puzzle set
    Transparent background, due to which the control buttons are not visible
    Buttons not responding
    After update
    The background remains transparent, in puzzles I remove the transparent background, the background becomes black, and the buttons are visible.
    Buttons do not respond to changes, showing errors
    What is the reason for this behavior of the scenes? Can you fix it?
    #52179
    solid
    This email was sent 10 days ago to sales@gliftek.com and you have not responded to my emails.
    Do you sell plugins, do they have technical support or not?
    #52360
    solid
    The developer does not keep plugins up to date. Doesn’t answer letters. Doesn’t return money. I don’t recommend buying these plugins.
    #52427
    GLiFTeK
    Hi solid,
    I do not have a ‘try and return’ policy , as these products are digital and delivered upon purchase.
    The plugins you’ve purchased are working fine, and I’ve sent you an email discussing your issues.
    My demo in the video that you are making changes to is just for learning purposes; how to use the plugin.
    I can’t be accountable for any errors you receive, after you’ve made any changes to it.
    #74855
    Brameister
    Hi GLIFTEK and anyone who can help.
    Is it not possible to rename a copied object?
    The issue I have here is that the “copy object” puzzle has a suffix input field, but it also adds another suffix to the object name.
    In your documentation, you show the following puzzle example:
    a
    That would be ideal, however, if I try to copy that same object, the copied object name is “Cube_Copy.000”
    If I try to rename “Cube_Copy.000” to “Red_Cube”, it doesn’t work.
    Is there any way to remove that added “.000” suffix or any other way to rename the copied object?
    Thanks!
    • This reply was modified 9 months, 3 weeks ago by Brameister.
    #74859
    Why not? It’s wotking quite good.
    But it won’t work with multi-material objects. Single meshes only. Some fixes needed.
    #74864
    Brameister
    That was exactly the issue. Could there by any way around this?
    #74865
    Easy
    #74867
    Brameister
    Easy
    Worked perfectly. Thanks so much for your help kdv!
