Home › Forums › Graphics / Blender › Glass material
- This topic has 9 replies, 2 voices, and was last updated 6 years, 12 months ago by
Mikhail Luzyanin.
2018-03-30 at 12:53 pm #3290
vincent
CustomerHave you a solution for express the glass. I don’t know the solution to make transparency. It isn’t necessary to make distortion like REFRACT, for me it is too much. Just more or less transparency. Option : The ideal will be a distortion with scale. .
2018-03-30 at 1:18 pm #3294Mikhail Luzyanin
StaffHave you a solution for express the glass. I don’t know the solution to make transparency. It isn’t necessary to make distortion like REFRACT, for me it is too much. Just more or less transparency. Option : The ideal will be a distortion with scale. .
Hi, Vincent. Is it necessery to refract what exectly above the glass or you can use a refraction of cubemap? Or you wnt to create a refraction of magnifier like in your example?
2018-03-30 at 1:46 pm #3300vincent
CustomerMy point of view. Refract is a a solid glass with mirror effect, and it’s not transparency. I can use a cube map, but it’s more true if it’s transparency with distortion “x 2” of object’s of behind. Yes like my picture !
2018-03-30 at 2:33 pm #3302Mikhail Luzyanin
StaffMy point of view. Refract is a a solid glass with mirror effect, and it’s not transparency. I can use a cube map, but it’s more true if it’s transparency with distortion “x 2” of object’s of behind. Yes like my picture !
Unfortunately it’s not in our plan for now to make a real-time refraction. What you try to implement may be it can be made using another techniques?
2018-03-30 at 2:40 pm #3304vincent
Customera glass on a watch
2018-03-30 at 2:58 pm #3311Mikhail Luzyanin
Staffa glass on a watch
Is it so critique to have a refraction on wathch glass for you? It will cause a weak effect of refraction on such small distance from the mesh.
2018-04-03 at 7:00 am #3344vincent
CustomerI would a material for glass effect, and it’s sure it’s not refraction ( case study : rabbit on the grass). Distortion or opacity… I don’t know the best way but not refraction,I send you a panel of images who express my goals.
2018-04-03 at 10:02 am #3350Mikhail Luzyanin
StaffYou mean a simple reflection with transperency like this?
2018-04-03 at 11:52 am #3352vincent
CustomerInteresting, a good effect with ring cube map, remains to know how to make these images. Thank you for your answer.
2018-04-03 at 12:28 pm #3353Mikhail Luzyanin
StaffInteresting, a good effect with ring cube map, remains to know how to make these images.
It’s not a cubemap exactly but a matcap. Just put a mirror ball somewhere in a scene then put a camera in front of it and render an image in ascpect ratio 1:1. Than conncet it as I made it in fold material, directly from normal output from geometry to Vector input in Texture node.
