Getting variable value from Articulate Storyline
Home Forums Puzzles Getting variable value from Articulate Storyline
  • #77480
    gulumse716
    Hi. I want to transfer the value of the slider_a_value1 variable defined on the articulate storyline to the slider_value1 variable in the webgl application created with verge3d, which has been added as a webobject to the articulate storyline. Even though I tried many times, I couldn’t figure it out.
    Verge3d side
    window.————- = function() {
    app.ExternalInterface.————-();
    On the articulate storyline side
    var iframeElements = document.getElementsByTagName(“iframe”);
    iframeElements[0].contentWindow.window.—————-();
    I can trigger a procedure by adding it, but I was not successful in transferring the value of the variable.
    • This topic was modified 6 months, 2 weeks ago by gulumse716.
    #77488
    It looks like you need to call a JS function inside iframe:
    https://stackoverflow.com/questions/251420/invoking-javascript-code-in-an-iframe-from-the-parent-page
