Tagged: annotation, autorotate camera: wrong controls type, camera, camera look at, camera settings, Camera zoom, navigation
- This topic has 10 replies, 2 voices, and was last updated 2 years, 4 months ago by
kdv.
2022-12-21 at 8:22 pm #59137
Brian
CustomerHello!
So in this example:
https://www.provia.com/wp-content/uploads/verge3d/115013/When I click an annotation, it zooms the camera to the proper location without jumping and animates perfectly. I have a separate call that shows a div in HTML and that is also working as expected.
The only issue I seem to have is the console throws the same error
“autorotate camera: wrong controls type” at EVERY frame until the user backs out to the previous Orbit Camera.(see screen shots attached)
How can I fix this issue? Can I just tell it to stop looking for autorotation? It seems to be listening for an autorotation event and I don’t know if there is a way to stop it?
You must be logged in to view attached files.2022-12-21 at 10:28 pm #59142kdv
Participantadd a condition, that will check what camera is active before activating autorotation.
2022-12-22 at 1:03 pm #59154Brian
CustomerHow do I force the orbit camera to look at the object smoothly without suddenly jumping? There seems to be a setting that I am not following.
A zoom, location, or FOV that I am not understanding.
2022-12-22 at 1:07 pm #59155kdv
Participantuse the
camera look at
ortween camera to
puzzlesPuzzles and JS coding. Fast and expensive.
2022-12-22 at 1:18 pm #59156Brian
CustomerOk I spoke too soon. Earlier, when learning verge3d, I realized that the camera would jump (sometimes violently) when coming to a stop after using the “look at” object command.
I had wrongly assumed it was because of camera controls, and generated a motionless feature camera, however having the user zoom in with the orbit camera, no longer causes a jump.
So what is the best way to restrict movement when the camera stops?
2022-12-22 at 1:42 pm #59157kdv
Participantshow your app (a link)
2022-12-22 at 2:41 pm #59158Brian
CustomerOk after all of that, I think I have it figured out. For any noob out there, if you are getting a “jump” when camera tweening, make sure that the camera’s FOV, rotation, and location are all accurate the final resting spot of your tween.
I hope that makes sense. I have it all working now with no errors. Time to clean up the file.
I’ll share it when I am not embarrassed by my code… :-P
Thanks for your help.
2022-12-22 at 2:46 pm #59159kdv
Participantmake sure that the camera’s FOV, rotation, and location are all accurate the final resting spot of your tween
exactly
2022-12-23 at 5:04 am #59173kdv
ParticipantBut it’s quite possible to make a smooth transition between two cameras with different parameters (FOV, position, rotation)
https://v3d.net/ctvPuzzles and JS coding. Fast and expensive.
2022-12-23 at 1:59 pm #59183Brian
CustomerGreat example, but does it throw an error if your zoomed in camera is set to “no-controls” ?
2022-12-23 at 2:05 pm #59184kdv
Participantno errors. as I said, it’s sufficient to check what camera is active before doing smth.
and I do not use cameras with no controls because the right click on the screen shows the browser conext menu, not needed.
