Home › Forums › General Questions › getMaterialByName not working.
- This topic has 4 replies, 3 voices, and was last updated 4 years, 2 months ago by GLiFTeK.
2020-09-29 at 2:17 pm #33567GLiFTeKCustomer
I’ve got a var of an object by getObjectByName.
ie:app.scene.getObjectByName(meshName);
works great.now to get the material in it, “metal”..
i have tobe all fancy and do this trick?…
var material = v3d.SceneUtils.getMaterialByName(v3d.apps[0], 'materialName');
but it does not work and says that material is undefined.
where in the documents can i find info about this and why’s it not working?
thanks!
plz share Discord link & on your signature!2020-09-30 at 7:33 am #33601Yuri KovelenovStaff2020-09-30 at 10:21 pm #33650GLiFTeKCustomerI’m trying to do it where WHATEVER the material from the object is named.. it can still dynamically get it from the object.. whatever object.
here is what i have..
(the cubes’s material name is “metal”.)
and here is my console readout…
material: visual_logic.js:477:13 metal visual_logic.js:478:13 mesh before script: visual_logic.js:480:13 Cube visual_logic.js:481:13 meshName: Cube visual_logic.js line 507 > Function:4:9 mesh after script: visual_logic.js:513:13 Object { uuid: "7E17F35D-5682-401F-9A60-BF011A861DB7", name: "Cube", type: "Mesh", parent: {…}, children: [], up: {…}, position: {…}, rotation: {…}, quaternion: {…}, scale: {…}, … } visual_logic.js:514:13 material before script: visual_logic.js:516:13 metal visual_logic.js:517:13 materialName: metal visual_logic.js line 519 > Function:4:9 material after script: visual_logic.js:526:13 null
this is being done because in the clipping planes script, you have to change a lot about the materials, and i like keeping materials that i’ve made in blender that have a lot of unique nodes etc. (this example is simple metal)
is this problem happening because i’m asking it about a variable value which is just a text name? how can i extract the material (whatever material) should i skip the get material puzzle and combine that’s code with the script code?
thanks!
You must be logged in to view attached files.Visit the GLIFTEK Verge3D Plugins Store!
plz share Discord link & on your signature!2020-10-01 at 8:39 am #33662Ivan LyubovnikovStaffIn the second exec script puzzle it should be:
var material = v3d.SceneUtils.getMaterialByName(v3d.apps[0], materialName);
instead of:
2020-10-01 at 8:44 pm #33706GLiFTeKCustomerO gosh.
Silly me.
Thanks IvanVisit the GLIFTEK Verge3D Plugins Store!
