Get Values in Material
Home Forums Puzzles Get Values in Material
  • #30235
    shawk5
    I am working with materials values in Puzzles and I found that there was no node to get values from the materials only set them.
    Specifically I would like a function that says when clicked set value in material to the current value plus one, is there an easy way to do this using puzzles or coding?
    #30250
    Yes, there’s no node for that, but you can copy this value every time on changing to the special variable so you always will know what you have there.
    #30256
    I’m going to add this task to our TODO list.
    X | FB | LinkedIn
    #31558
    shawk5
    Thanks for the quick update, it has saved me a lot of time, and from having to create a ton of variables :good:
    #31574
    :good:
