Get Intersecting objects’ dimensions?
Home Forums Puzzles Get Intersecting objects’ dimensions?
  • #80107
    c4cc
    First off, credit of kdv for helping me solve this.
    Now, I’m trying to get objects’ dimensions, to determine when an object touches another, the latter will disappear. (The movable object here). I need the moveable object here to vanish when the shot touches its surface, even if slightly
    ol4x1
    Relevant puzzles
    ol4x1
    Yet get object dimension puzzles does not work here?
    ol4x1
    or here?
    ol4x1
    Zip app here
    https://drive.google.com/file/d/1HnzuBNS6x-0kh4NU5J1evnu3FFr-jU62/view
    #80121
    or here?
    incompatible puzzles (and wrong logic in your head). it’s not possible to measure distance between a number and an object. it’s not possible to compare a boolean value with a numeric value…
    The first puzzle set is working. You just need to replace 0.05 with 0.25. And why are you hiding the player object instead of bullets? :scratch:
    #80122
    c4cc
    Fair enough
    I hid the player object to test if the distance between puzzles were indeed working
    I’m trying to get dimensions of an object, to calculate when other objects that comes into contact with said dimensions.
    On the other hand, using “distance between” puzzles is inaccurate in determining contact between objects, even if the number for this puzzle is bigger.
    The browser game I’m working on has characters of irregular shape you see. Imagine a Blender’s suzanne. Not basic shapes like in the above example. If I use distance between puzzles, it’s inaccurate to calculate effect if contact unless I get dimensions of both objects
    #80123
    c4cc
    Imagine a Blender suzanne in the above example, as playable character. Its origin is at the face middle. Let’s say shots fire and hit it’s ear, but nothing happens, so I increase the “distance between” puzzle number.
    if that suzanne moves up to avoid the shot, the damages still applies (even if lesser) because the distance between puzzle still computes damages based on distance between shot and suzanne.
    so I need to get dimensions of suzanne to determine if shots do damage or not
    #80189
    ~0.258 is a dimension of your cube. That’s where you can use “get dimension” / 2 instead of 0.05
    #80190
    c4cc
    Need the shots to disappear if they come into contact with the cube’s dimensions.
    Tried but sadly shot’s don’t disappear even though they touch cube’s dimensions.
    l41
    #80191
    Tried but sadly
    *facepalm* a remainder of a vector divided by a number? :wacko: the result will be NaN (nothing)
    #80192
    c4cc
    This works, thanks. I’m just trying to make my puzzles accurate as yours.
    Btw, what size is your shots? mine’s are 0.2 for x, y, z dimensions.
    l41
    my puzzles:
    l41
    Also, at .20 in your video, the shot whizzes over your red cube…
    l41
    whereas in mine, if I’m extremely close to, but not touching the shot, it vanishes
    l41
    • This reply was modified 2 months ago by c4cc.
