- This topic has 6 replies, 5 voices, and was last updated 3 years ago by
Mikhail Luzyanin.
2022-12-01 at 5:26 am #58735
hoahaithanh
Customerhi,
get animation puzzles does not work with object’s animation created in edit mode.
hope it fix in the furture :)
2022-12-01 at 8:46 am #58770
Yuri KovelenovStaff2022-12-05 at 2:02 am #58826hoahaithanh
Customerhi,
This animation created in edit mode. It work in blender but not in v3d.
2022-12-05 at 5:40 am #58835
xeonCustomerI was wondering what your reasoning was for animating the vertices rather than just moving the object or just creating shape keys. Although you can animate various parameters in Blender in edit mode manually or using the Anim All plugin.
I have tried to get this sort of animation to work in 4.1.1 but it will not. The Puzzles will recognize the group but will not pickup the individual vertices associated with that group from what I can tell.
I am also curious to hear back from Soft8Soft. With your test scene that has 275 vertices that are animating I am wondering what the performance efficiency would be vs just animating the object. Seems like moving a single origin point for a single object would be more efficient but I could be wrong…… waiting and watching.
Tutorials - https://www.xeons3dlab.com2022-12-05 at 5:42 am #58837
xeonCustomerresource link to what type of animation is supported:
https://www.soft8soft.com/docs/manual/en/blender/Animation.html#Whole_Object_AnimationXeon
Tutorials - https://www.xeons3dlab.com2022-12-05 at 5:51 am #58838kdv
Participantone question: why? ))) and this animation doesn’t work in Verge3D because it’s not exported from Blender.
app.actionsis an empty array.Puzzles and JS coding. Fast and expensive.
2022-12-05 at 6:33 am #58839
Mikhail LuzyaninStaffIf you want to use vertex animation in the engine you need to animate shapekeys or bake it to shapekeys. Look at this video.
