Get a reference to a specific Object in Scene
Home Forums Puzzles Get a reference to a specific Object in Scene
  • #15603
    Alby90
    Hi guys…
    I want to make a Configurator that let me change various model (with Scene Append) and change the main texture of the object.
    I think i understand how to load an object and change textures but the problem is…how can i change the texture of the first material on the last spawned object?
    There is a way to store a reference to that object after is spawned or is possible to do something like:
    -Get all the objects
    -Foreach Objects in the scene: if THIS object has this name THEN put him in this variable.
    Maybe is a stupid question but i cant figure out. :scratch:
    #15609
    If you’re using Puzzles, you can reference an object simply by its name put in a Text puzzle.
    #15612
    Alby90
    Thanks … so I can simply compare the name of the object as if the variable that contains it is just a string.
    And for change the texture? The “Replace Texture” puzzle requires you to select the exact texture I want to change in the material, so how can i just change the texture in the material of an Object i just spawn?
    Thanks in advance
