Home › Forums › Programming › Geometry Buffers cleanup
- This topic has 10 replies, 3 voices, and was last updated 2 years, 1 month ago by
kdv.
2023-01-16 at 8:41 am #59598
scatman2513
ParticipantIm cloning and deleting a lot of objects and after too much operations my application drops significant in fps. I’ve looked into the performance info and saw that my “Geometry Buffers” grows constantly. Like having 1 group of objects shows me 17, but if I clone it 30 times and delete it 30 times it grows to over 400.
I have a render function that should delete everything and draw it new. How do I delete everything before creating my structure again?
2023-01-16 at 8:47 am #59600kdv
ParticipantShow your code. And note that if you’re using the
clone()
function for a mesh its geometry is not cloned. Theclone()
function creates an instanced mesh sharing the original geomtry buffer.In this demo the scene contains 80+ objects and only 2 geometry buffers
https://cdn.soft8soft.com/demo/blender/clone_object/clone_object.htmlA geometry buffered can be removed from memory this way
object.geometry.dispose();
2023-01-16 at 2:14 pm #59611scatman2513
ParticipantIt took me a moment to create a demonstration application for my problem. I’ve attached the .zip into my post. I have to say that I’m working with a plugin from gliftek to duplicate my objects.
The logic is built into the puzzle. If you take a look into the console output, then you can see how Gemoetry Buffers is growing while objects stay the same.Attachments:
You must be logged in to view attached files.2023-01-16 at 6:27 pm #59618kdv
ParticipantYour
render()
function creates 140+ new objects. I don’t see so many ones in the scene. That means there are a lot of unwanted duplicates.
The initial amount of the scene’s children is 9.The cloned balls (expected) do not create additional geometry buffers but the matrix’s cubes do. Every time +16 buffers. If you remove a box creating from the
render()
function you’ll see that the geometry buffers amount doesn’t grow up. In fact, it’s not so much, the cube’s geometry contains only 8 points.The cloned balls (not expected) create a lot of additional materials every time instead of sharing the initial material.
Finally, add this code to dispose of the old geometriy buffers
2023-01-24 at 5:52 pm #59823scatman2513
ParticipantThis worked perfect. Thanks. Now I can duplicate and delete objects and “Geometry Buffers” isn’t growing anymore.
However, in my application (not the demo project I shared above) I still have performance issues and a look into the performance info shows me that “Textures & Render Buffers” is still growing. I also have these “N/A Textures” calculating up.
I tried to change your code to delete materials first but it had no effect..
VARS.allDupedObjects.forEach(function(name){ const object = app.scene.getObjectByName(name); if (object && object.isMesh){ object.material.dispose(); object.geometry.dispose(); } });
Do you know what’s the problem here?
If you need a demo application I could create one end of the week.best regards
You must be logged in to view attached files.2023-01-25 at 3:04 am #59833kdv
Participanttry this code
app.scene.traverse(function(object) { if (object.isMesh) { v3d.MaterialUtils.disposeTextures(object.material); object.material.dispose(); object.geometry.dispose(); } });
2023-01-25 at 3:17 pm #59874scatman2513
ParticipantThank you a lot @kdv. The issue is fixed now. After calling the render function nearly 100 times I always get the same numbers now in the performance info and the fps-drops have stopped now. Fantastic! Made my day = )
2023-02-22 at 2:07 am #60574auriea
CustomerIn my scene I’m also having this kind of problem. It’s just a normal scene with maybe 30 objects in it though. But it seems this red number goes up the longer I play my project, so I’m worried.
Would some variation of the above code help me make my scene faster?
--- Verge3D Performance Profile (1s) --- v3d.js:1:1066937 Scene Loading Time: 4872ms v3d.js:1:1066937 Asset Compression: yes v3d.js:1:1066937 FPS: 59 v3d.js:1:1066937 Render Calls: 8 v3d.js:1:1066937 Triangles Rendered: 51708 v3d.js:1:1066937 Geometry Buffers: 7 v3d.js:1:1066937 HDR Rendering: no v3d.js:1:1066937 Viewport Resolution: 3423x870 v3d.js:1:1066937 Pixel Ratio: 1 (current) / 1 (device) v3d.js:1:1066937 Image-Based Lighting: PMREM 512px v3d.js:1:1066937 Lights: 1 v3d.js:1:1066937 Reflection Probes: 0 (cube) / 0 (plane) v3d.js:1:1066937 Post-Processing: Render,ToneMapping v3d.js:1:1066937 Shadow Map: N/A v3d.js:1:1066937 Materials and Shaders: 10 v3d.js:1:1066937 Verge3D_Environment_World - MeshNodeMaterial - 0ms v3d.js:1:1066937 System Material - SphericalGaussianBlur - 0ms v3d.js:1:1066937 CubemapToCubeUV - CubemapToCubeUV - 0ms v3d.js:1:1066937 System Material - ToneMap - 0ms v3d.js:1:1066937 CAVE-innerWall - MeshNodeMaterial - 0ms v3d.js:1:1066937 leaf - MeshNodeMaterial - 0ms v3d.js:1:1066937 CAVE-innerWall - MeshNodeMaterial - 0ms v3d.js:1:1066937 branches - MeshNodeMaterial - 0ms v3d.js:1:1066937 Earth-atmosphere - MeshNodeMaterial - 0ms 2 v3d.js:1:1066937 Total Render Time: 0ms v3d.js:1:1066937 Textures & Render Buffers: 846 v3d.js:1:1066905 dusk2-1k.hdr - Texture - 1024x512 - RGBA v3d.js:1:1066937 Trreoflife2Leaf.png - Texture - 256x256 - RGBA_BPTC v3d.js:1:1066937 EffectComposer.rt2 - RenderTarget - 3423x870 v3d.js:1:1066937 EffectComposer.rt1 - RenderTarget - 3423x870 v3d.js:1:1066937 PMREM.cubeUv - RenderTarget - 1536x1536 839 v3d.js:1:1066937 N/A - RenderTarget - 1024x1024 v3d.js:1:1066937 N/A - RenderTarget - 512x512
You must be logged in to view attached files.2023-02-22 at 3:50 am #60581kdv
ParticipantMaybe. Show your puzzles.
2023-02-22 at 6:42 am #60585auriea
Customer@kdv Would it be possible for me to share the project to you privately? Since I’m not so familiar with Verge maybe I could do a (paid) consultation with you for this? I’d really like for this project to run well in the browser, but I’m probably doing all kinds of tricky things.
2023-02-22 at 10:32 am #60590kdv
Participantcontact me at kdv [ at ] izh [ dot ] com
