- This topic has 3 replies, 2 voices, and was last updated 4 years, 7 months ago by
Ivan Lyubovnikov.
2020-06-21 at 6:56 pm #29031
GLiFTeK
CustomerHi,
So say i have four 512 x 512 images, and want them combined into a long image 512 x 2048.Instead of using yet another library for just one thing, like merge-images.js, could this be done by somehow using the code behind the “texture from text” or “generate normal map” puzzles?
The 512 x 512 images used would be already in the same directory, so no need to upload or retrieve from elsewhere, (ut that might come in handy at a later time perhaps.)
Any info on this would be great.
Thanks!Visit the GLIFTEK Verge3D Plugins Store!
plz share Discord link & on your signature!2020-07-03 at 10:25 am #29611Ivan Lyubovnikov
StaffHi,
This can’t be done directly by using “texture from text” or “generate normal map” puzzles but the approach is similar (and also very close to what merge-images.js does).
If you don’t want to have an additional dependency in your project you can just write a simple function specifically for your needs:
function combine(imgSources) { return Promise.all(imgSources.map(function(url) { // load all images return new Promise(function(resolve) { var img = new Image(); img.onload = function() { resolve(img); }; img.src = url; }); })).then(function(images) { // create a canvas with required dimensions var canvas = document.createElement('canvas'); canvas.width = 2048; canvas.height = 512; // draw images to the canvas var ctx = canvas.getContext('2d'); ctx.drawImage(images[0], 0, 0); ctx.drawImage(images[1], 512, 0); ctx.drawImage(images[2], 1024, 0); ctx.drawImage(images[3], 1536, 0); // return the resulting image in base64 form return canvas.toDataURL('image/jpeg'); }); }
It loads all the given images and after they are ready creates a canvas with dimensions 2048×512. Then it just draws all the images into the canvas with some offsets that you can specify in
ctx.drawImage
. The function returns a string in base64 format which looks likedata:image/jpeg;base64,/9j/4AAQSkZJRgABA...
.You can use it to create and add a new image onto the page:
combine(['1.jpg', '2.jpg', '3.jpg', '4.jpg']).then(function(result) { var img = new Image(); img.src = result; document.body.appendChild(img); });
Btw, if you use this canvas approach there’s a limit for the maximum width and height for the combined image: https://developer.mozilla.org/en-US/docs/Web/HTML/Element/canvas#Maximum_canvas_size
2020-07-04 at 5:11 pm #29645GLiFTeK
CustomerHi,
Thanks Ivan!
I’ll try it out!
is (ImgSources) an array?
plz share Discord link & on your signature!2020-07-09 at 7:59 am #29869Ivan Lyubovnikov
Staffis (ImgSources) an array?
Yes, it’s supposed to be an array if image URLs.
