GamePad DPAD press issue
Home Forums Puzzles GamePad DPAD press issue
  • #19878
    GLiFTeK
    Hi
    I’ve been trying for about 2 days to figure out what i’m doing wrong here on this issue with the DPAD on the GamePad.
    it’s a simple 5 item menu that i scroll through vertically.
    i tried the increase variable by 1/-1 etc .. but it keeps on being played EVEN when i tell it a variable that would have it not repeat once the conditions are met.
    I have to call to see if it’s conditions are met every frame, but when they’re met i haven’t found a way to cease it from over “doing it”
    instead of selecting items… they all just flash like markquee lights REAL fast.
    any ideas?
    thanks!
    EDIT: AAAH! … used the time puzzle “after _ seconds do this” .. put it after it to give a buffer before i undid the limiter variable that allowed the every second procedure. ..
    man that saved the day(s) .
    … the moarz ya know!
    #19882
    glad you worked it out!
    #19885
    GLiFTeK
    also, since i’ve been working with the GamePad puzzles a lot,
    i’d like to point out things that some people may have issues with but it would be good to know in advance…
    having more than one tab/window open connecting to the gamepad will cause problems.
    i figured this out..
    but then had to figure it out a second time when the window that was interfering was the one behind my puzzles that i hadn’t used in months.
    now i use that for the gamepad testing
    .. however can be pesky if you have a bad loop/error.. stalls and halts you from getting to your puzzles
    #19908
    I’ve just tried to reproduce this bug, however, running gamepad in multiple tabs simultaneously works fine for me. Can you provide more details on this issue?
    X | FB | LinkedIn
