game engine like workflow with baked material
Home Forums Graphics / Blender game engine like workflow with baked material
  • #28888
    lopatam
    Ciao,
    I’m trying to recreate a game-engine workflow where the material has the diffuse baked (used as emission) and reflections in real time (not RT realtime).
    My scene doesn’t have light but I need reflections from an hdri map or whatever.
    I tried via puzzle to enable screen space reflection but it doesn’t support glossy reflection, and I don’t get good result.
    Is it possible?
    Thanks in advance
    #28889
    You can put environment pat directly into material and combine it with a diffuse map how you want. Look at the example.
    #28895
    lopatam
    but I don’t know how to combine a shader with a baked map plus a reflection map.
    If I add an environment map in the world setting it lights the scene.
    If you have time can you look at my scene.
    #28897
    lopatam
    and here is the final look I need.
    #28899
    lopatam
    This is a comparison between the render and what I get in webGL. Top is render, bottom is webGl
    #28905
    Ssr is very slow. Better to use environment maps and reflections from the point light.
    #28907
    lopatam
    I’m sorry but I don’t understand your solution. I don’t have any light in the scene, everything is baked.
    #28911
    Here’s I’ve made some changes in your example. It’s a very tricky way, but it’s the only way to get what you want. Better to bake separate reflection mask for better control where environment map must be shown.
    #28913
    lopatam
    Thanks!!! It’s what I need. The sphere doesn’t reflect the floor, I think I’ve to create the environmental map based on the scene, but for a particular job I’m doing it works very well. Thanks again!
    #28918
    Yes, to get exactly the same reflection better to bake environment map from the scene. Good luck :good:
