Full screen button
Home Forums General Questions Full screen button
  • #42745
    gf3d
    Hi there,
    is it possible to use 3D generated objects ( created in 3D Max )
    as buttons to do the fullscreen function and back again?
    Greets
    Ger
    #42823
    gf3d
    Hi there,
    has anyone read this?
    I´m creating a pure 3D Konfigurator….so i need a solution ( if possible) to have a 3D object to do Fullscreen and back again.
    The default fullscreen function i cannot use..i need it to stay at its position,
    Greets
    Ger
    #42830
    Read…yes.
    Have an easy defined workable solution. No.
    Some concepts you may have tried and not have had any success and I don’t know if they would work.
    From the init tab or direct creation…create an HTML element and set it up as the full-screen button. Then on your object create an on-click event that sets a property that is read by your HTML element. On a good event..trigger full screen. If that works…then minimize the HTML element to a single pixel and hide it somewhere in the scene.
    Another option that I feel might be less likely to work is to create a transparent image and bind it to your object. Then just make the transparent image a button for full screen.
    Not sure any of this would work and you may have already tried these with no sucess.
    Watching to see if anyone else has done this.
    #42839
    gf3d
    Hi there,
    sorry but i don´t know what you mean…i´m not into programming…
    It can´t be that difficult to have a black background when the application starts…i´ve seen such thing alraedy…
    Greets
    Ger
    #42840
    I was answering the full-screen button question you posted. Not the black screen issue.
    Without some level of programming, I don’t believe there is a solution but perhaps someone on this forum has a solution that I am not aware of.
