Home › Forums › Bug Reports and Feature Requests › Found an install limitation (not bug, but…)
- This topic has 3 replies, 2 voices, and was last updated 2 years, 7 months ago by
Alexander Kovelenov.
2022-08-31 at 8:33 am #55390
NaxosCG
CustomerHello team !
My son is showing some interest for Verge3D stuff, so i tried to install it on his PC, 4.1.1 free demo.
On my PC, i have only one user account, so it is admin.
On his PC, i have admin account, and his user account : i do that for children as if the system asks for admin password while he is not actually installing stuff, this is suspicious, and it is a good way to add security.Problem is, since windows 10, the C:, and C:\programs are not available for read when you are logged as simple user (not admin).
Of course, when i statt install for Verge3d, it says that it can’t write files. Logical.
So i right-click / start as admin the installation exe : and it can copy files and so on.
BUT : it installs stuff for the admin session, not the current user one, and 3dsMax does not have the Verge3D menu.
I first thought about some max bullshit, and tried several ways to manually create this menu : no success, of course, the created menu does not find scripts and so on.After 2+ hours testing, i find the (bad) solution :
I’ve changed the ownership / security acces for c:\programs files so that current user can write files into it.
Started Verge3D installation as current user (not admin), and it worked.I think you should change the installation process to install verge3D for all users (like some other softwares), it could solve this issue.
Bets regards.
2022-08-31 at 1:30 pm #55400Alexander Kovelenov
Staff2022-08-31 at 2:03 pm #55403NaxosCG
CustomerOk, but the default is within program files, and i guess it has to install stuff in the autodesk / 3dsmax 20xx folder.
I mean, if i let all by default, i get the “can’t write file” error, and can be confusing for artists guys.
I’m sort of an hybrid guy : 80% artist, 20% maths/code, 100% nerd.
And i had to find this workaround to get it installed, and it took me 2+ hours to get it done.So just maybe if it could be simplyfied…
2022-08-31 at 4:53 pm #55423Alexander Kovelenov
Staff -
