Force Browser for 72 fps for VR
Home Forums General Questions Force Browser for 72 fps for VR
  • #72568
    tomtm
    Is there a way to limit max fps to 72 and also the
    Frame Refresh Rate of a VR Headset, to get a stable 72 FPS ?
    In some compex scenes, it‘s not possible to constantly get the 90 fps.
    Thanks
    Tom
    #72569
    You can limit the refresh rate in your headset using SideQuest (from PC) or Quest Games Optimizer (directly from a headset). But your customers will have to do the same. Limiting FPS in three/v3d apps is not provided. Refresh rate is limited by the monitor refresh rate (VSynch).
    #72571
    tomtm
    Hi kdv
    Ok, thank you for this information.
    I realized, that many games or other VR Projects availabe are running at 72 fps, which is better than have a display refresh rate at 90 and dropping fps even it runs most of the time at 84 -90 fps.
    #72573
    other VR Projects
    Where?
