Flying in object choppy
Home Forums Puzzles Flying in object choppy
  • #30802
    web
    I’m trying to do a intro animation. The object is outside of the camera sight, and I want the object to move into it.
    Problem is that when the object becomes visible the animation is choppy the first 1-5 frames. I think that verge try’s to dynamically load shaders and stuff.
    How can I prevent that and get a silky smooth animation?
    #30822
    Can you share the project? Or reproduce the problem on a simple file?
    #30845
    web
    Sadly I cant share the files in public. I tried to reproduce a simple file but it seems to be a sum of things and not single parts. When I apply one material to all the objects the animation is running smoothly from start to end.
    The geometry is around 360k polys, consisting of 67 single objects grouped together (using 3dsMax btw). 192 render calls, 64 geometry buffers.
    At the moment I discarded that approach, and just let the whole v3d-container fade in.
    #30859
    You can try to disable each thing one by one, for example disable material, shapekeys (if exist), armature etc. to understand what exactly produce such behavior.
    #30861
    web
    Thx for the tip. I already tried that approach but couldnt find “the material”. Its really a sum of all.
    When I find a way to reproduce it will write back here.
