First person camera mode not working probably
Home Forums Bug Reports and Feature Requests First person camera mode not working probably
  • #24330
    Draco080
    when i run the app using run app button first person stop working and i can only moving from my mouse wasd stops working, run HTML enables first person again and i can use wasd same as in puzzle mode, but when i run the app with some HTML code first person stops working, i used the html code from here
    https://www.soft8soft.com/docs/manual/en/introduction/HTML-based-user-interfaces.html
    to make two buttons and each button has the code in the pic, camera set to first person and with collision material enabled, AWSD only stops working when there is HTML code, and the code works it jumps to the location of the empty object but i need to use WASD too
    #24348
    May be there is a div that covers an iframe so the buttons can’t be detected. Try to make all you buttons withoit an invisible div that covers an iframe div with the app.
