FEATURE REQUESTS :text mode support UTF8 character
Home Forums Bug Reports and Feature Requests FEATURE REQUESTS :text mode support UTF8 character
  • #462
    xuekepei
    Hi team,
    I play around new version verge, find that when put chinese in puzzled block ‘text’ ,and push run button, the 3D viewport just show a “?” not the right font.
    I know support this need do much work like font load and more. so, write a feature request here for note.
    thanks.
    #463
    Hi Xueke,
    Yes, this feature needs UTF font support. We are going to make it available in the final release. It will be optional though, since the full set of characters brings additional 20 Mb in file size.
    #464
    xuekepei
    Thanks yuri,
    another question: did the puzzled block UI possible i18n to other language? If could
    then configurable or hardcode?
    #465
    Yes, Puzzles can be translated to other languages. We can do Chinese translation in the future.
    #3425
    baohua
    HI, found the same issue. While in the example application “international_text” it can display Chinese characters correctly. In this example it uses “BfontInt.ttf” font, I try this font and the issue still there. Is there any differences with that or other ways to get it?
    #3426
    baohua
    I created another application and with the same model file, it works fine.
    This may the cached older model file cause the problem.
    #3434
    Great you worked that out! For your information, since version 2.2 Verge3D offers a way to load and use any fonts. See the Custom fonts section in the release article.
