Feature request – transfer puzzles to another tab
Home Forums Bug Reports and Feature Requests Feature request – transfer puzzles to another tab
  • #77332
    David Duperron
    Hi!
    Another puzzle editor feature request that would be very useful I think: being able to transfer a puzzle (or selection of puzzles) to another editor tab without copy/paste.
    Copy/Paste will work most of the time, but when you want to transfer a procedure, if you COPY/paste this will create another version of the procedure (with a “2” added to the name) and therefore you need to modify all the instances of the procedure everywhere else… And if you CUT/paste, the editor just removes all the instances of the called procedure everywhere! like when you delete a procedure and the editor automatically deletes where it’s called…
    I know that I can do that directly in the visual_logic.xml and move the <block> from one tab to another, but this requires to edit the XML file independantly, and reload the puzzle editor, which can take some time for large puzzles with many tabs.
    #77334
    muhuzhongxun
    Feature Request for Moving Defined Procedures
    • This reply was modified 7 months, 1 week ago by muhuzhongxun.
