Home › Forums › Bug Reports and Feature Requests › [feature request] debug loading times
- This topic has 6 replies, 2 voices, and was last updated 4 years, 4 months ago by
thomasup.
2020-11-04 at 8:42 am #34998
thomasup
Customerwe are currently trying to optimize the loading times on our scene, but find it hard to find the influencing factors.
we have to make changes and run multiple performance tests. this process makes it hard to consistently recreate differences in loading times.
it would be helpful to see how much different parts account to the loading time, similar to how it is done with the performance profile.
it would be interesting to see how much these things contribute to the total loading time:
– vertex / poly count (we measured small differences here, the effort in reduction does not seem to pay out)
– file size (this seems to have a small impact, download times are the smaller part of our loading times)
– unpacking (we found lzma compression to make loading times longer, especially on low end devices. enabling gzip for .bin files on the server side was an improvement though)
– texture count / size (suprisingly, we barely measured any difference here, differences were smaller than the “noise”)
– shader count: we are still testing this one
– object count: does it have an impact?
– any other big factors: ???overall we are left with several seconds of loading time, and find it hard to pin them down to anything? what is happening there? how can we improve it?
2020-11-04 at 9:29 am #35008thomasup
Customerso it seems like the amount of materials / shaders accounts to ~1/3 of our loading time… that is heavy, but understandable, since we had 102 materials going.
this will give us room for improvement now.
still, a feature that simply prints out the contributing factors/times in the console could save loads of time in finding the shortcomings
2020-11-04 at 11:09 am #35024thomasup
Customerwe made a short script, that list materials which could be converted to gltf2 materials:
import bpy # count the materials using gltf2 compatible gltf2count = 0 print("gltf2 compatible material enabled on:") for m in bpy.data.materials: if m.v3d.gltf_compat: gltf2count += 1 print(m) print("gltf2 Materials: " + str(gltf2count)) print("") # find simple materials, that could be converted to gltf2 print("simple materials to consider making gltf2:") for m in bpy.data.materials: # get the material node tree nt = m.node_tree node_count = 0 # loop all nodes for n in nt.nodes: # do not count output nodes, or principled BSDF nodes if n.type != "BSDF_PRINCIPLED" and n.type != "OUTPUT_MATERIAL": node_count += 1 # if the material has less than 2 remaining node, list it in the console if node_count < 2 and not m.v3d.gltf_compat: print(m)
it is very basic for now, but helped us quickly find the materials that can be converted without visual changes.
2020-11-04 at 1:32 pm #35042Yuri Kovelenov
StaffHi,
if the content was loaded once, it gets cached which may significantly influence the measurements. For a fresh load counts all the factors you mentioned (basically the more content you load the longer it take to process). It is difficult to define any percentages because of very different hardware the user may have. 102 materials is a lot, may be you could consider loading some of them on demand.
Thanks for sharing the script!2020-11-12 at 11:10 am #35272thomasup
Customerindeed, there are many factors to it. basically, the proposal was to add more metrics to the performance profile.
currently, it only says:
Scene Loading Time: 24111ms
my proposal would be smth like:
Total Scene Loading Time: 24.11s gltf Download: 2s decompressing: 1.2s Loading Geometry: 4.10s Texture Loading: 2.3s Compiling shaders: 8.20s Scene Setup: 0.5s
this would give a quick and easy way to start optimizing the load times, without having to do performance tests on various devices, multiple times, comparing load times etc.
i think this would be a valuable feature.
2020-11-12 at 11:39 am #35279Yuri Kovelenov
Staff2020-11-12 at 2:09 pm #35288thomasup
Customerthank you! that would be very helpful!
