Fake path Warnings
Home Forums General Questions Fake path Warnings
  • #13409
    Luke224
    Hi are these Fake Path Warnings Something i should fix or are they irrelevant?
    v3d.js:1 v3d.WebGLProgram: gl.getProgramInfoLog() C:\fakepath(336,23-154): warning X3571: pow(f, e) will not work for negative f, use abs(f) or conditionally handle negative values if you expect them
    C:\fakepath(579,87-141): warning X4122: sum of 4e+016 and 1 cannot be represented accurately in double precision
    C:\fakepath(386,10-65): warning X3571: pow(f, e) will not work for negative f, use abs(f) or conditionally handle negative values if you expect them
    C:\fakepath(397,8-60): warning X3571: pow(f, e) will not work for negative f, use abs(f) or conditionally handle negative values if you expect them
    C:\fakepath(340,25-100): warning X3571: pow(f, e) will not work for negative f, use abs(f) or conditionally handle negative values if you expect them
    #13413
    Those are WebGL warnings produced from shader code. There are harmless. It’d take much effort to get rid of them though so we decided to not touch them yet.
