Facebook GitF Interactivity?
Home Forums General Questions Facebook GitF Interactivity?
  • #17085
    grimmy
    Hi, I just stumbled upon Verge3d by accident even though I’ve been looking for a decent 3d HTML5 engine for years!! It looks amazing so far! I was just wondering if puzzles/code/interactivity works with the Facebook GitF export. I presume not but I thought I’d ask.
    Cheers
    Simon
    :bye:
    #17087
    Facebook glTF export option is basically a more restricted format of Verge3D glTF export, so I think Puzzles should work in this case.
    UPD if you mean whether Facebook can handle Verge3D Puzzles/ code then answer is no, as Facebook offers their own web viewer which is not scriptable (yet).
    #17100
    grimmy
    Actually I just tried adding the built in cube example to a facebook post but when I drag the exported cube.gld on the facebook post area nothing happens at all.
    In the console it reads:
    ErrorUtils caught an error: “Undefined attachment id: FILE”. Subsequent errors won’t be logged; see https://fburl.com/debugjs.
    b @ GOvppS2Z89x.js:52
    #17116
    It looks like Facebook recently removed the possibility to post 3D models in favor of 3D photos. That’s sad. :cry:
    https://developers.facebook.com/docs/sharing/3d-posts
    You can still use embedable 3D applications with Facebook as it was before 3D posts.
    Anyway, thanks for pointing that out. We’ll update the UI and the documentation accordingly.
    #17117
    grimmy
    Ooh, that’s quite a major set back :( How exactly do you put an ’embedable application’ on Facebook? DO you just mean a regular facebook application? or it there some way of pushing an application as a post?
    #17118
    Yep, I was meaning the standard FB apps
    https://developers.facebook.com/docs/apps
