Export .GLTF
Home Forums Graphics / Blender Export .GLTF
  • #3576
    vincent
    I can’t export my file and make the update for the my work with App Manager.
    I do not have an error message. Is it my App Blender or something inside my model 3D ? Thanks for your interest ?
    #3582
    vincent
    Oh my god ! I make a mystake.
    Two objets have a same name.
    There is a problem with parent and bone !
    #3599
    I think you found some kind of bug that we already fixed and it will be awailable in the next release.
    #3601
    vincent
    At what time it happens ? I am stopped
    #3607
    If you link something from another file that has identical name as the object in your main file and made it localy. Try to rename identically named objects/meshes.
    #3662
    vincent
    The problem does not come from the names, independently Verge 3d works.
    Name’s vertex. I don’t write a name for the vertex.
    #3668
    Meshes with the same name also can cause the issue because the same naming, try to rename some of them. Can you also send us a blend file to be sure that it’s the same bug that I think?
