Home › Forums › Bug Reports and Feature Requests › Explorer not loading
- This topic has 10 replies, 3 voices, and was last updated 8 years, 1 month ago by
Mikhail Luzyanin.
2018-05-18 at 4:30 pm #4242
johngrigni
CustomerI just get the spinning hexagon and 0%, but it never loads.
2018-05-18 at 9:02 pm #4246johngrigni
CustomerHere is the link to the project:
http://www.argosdesigns.com/ATI_Lobby/index.htmlIf you want to see it without the buttons in front, the scene is here:
http://www.argosdesigns.com/ATI_Lobby/ATI_Lobby.htmlIt works on Safari, Chrome, and Edge, but it seems to simply not load in Internet Explorer.
2018-05-19 at 10:52 am #4247
Yuri KovelenovStaffHi,
We don’t support IE because this is rather old browser which was dropped by Microsoft and it lack features currently used for loading glTF files (promises to be exact). It’s market share is about 3% and decreasing. However, if you strongly need to support IE11, you can try using the shim that I referenced.
2018-05-19 at 12:59 pm #4248johngrigni
CustomerI’m not very good with coding, and that seems a very deep rabbit hole of coding.
I can download the ZIP and put the contents in the app directory, but I really am not sure what I need to do from there – it mentions some lines to add for CDN (I’m assuming I add them to my ATI_Lobby.html head), and goes on to mention some other things I have no idea about, like ‘Node.js’ and ‘Usage in IE<9’.
I hate to ask you for more specifics, but I’d be willing to pay for your time.
2018-05-20 at 9:00 am #4249
Yuri KovelenovStaff2018-08-30 at 5:14 pm #6840johngrigni
CustomerI was just told by my client that the app isn’t loading in explorer. Here is the url, and I’m attaching a screenshot they sent me.
http://www.atilaminates.com/visualizer/index.html
EDIT – looking at the screenshot, it is loading, but most of the model is not. You should be looking at a room with a counter. The little white ovals are actually lights in the ceiling – I have no idea why they show up and not the ceiling itself or the walls.
2018-08-30 at 5:22 pm #6842johngrigni
CustomerI’m seeing a similar problem in Edge. I did implement your fix for Internet Explorer, unless they made more changes to some remote library to undo that.
2018-08-31 at 3:03 pm #6858
Yuri KovelenovStaff2018-09-02 at 8:33 am #6865
Yuri KovelenovStaff2018-09-06 at 3:16 pm #6975johngrigni
CustomerI took your advice and turned off shadows, and it worked.
I tried to bake shadows, but the UV maps for the wall panels are repeating and the shadows aren’t. Is there a way to have more than one UV map on a mesh? It always fails for me. I was thinking of making a translucent black object in front of the walls with an alpha channel based on the shadows, but doesn’t seem to work either.
2018-09-07 at 5:49 pm #7007
Mikhail LuzyaninStaffI tried to bake shadows, but the UV maps for the wall panels are repeating and the shadows aren’t. Is there a way to have more than one UV map on a mesh?
Hi, John. You can easily create second or more UVMaps and use them in your material, but you will need to create your matrials using nodes not a simple “stack” material. You can create second UVMap as texture atlas and bake Ambient Oclussion and smooth shadows to it. Laso it’s best way to optimize you scene is to leave only one light with shadow casting and also minimize overall amound of lamps in the scene for to bake lighting and add his texture after the material node (before output node) using Addition, so this will imitate loghting especcialy it will work very good on walls light and Built-in lighting. You can fix this baked lightmap with another tiled texture so it will give a good fake effect of smooth light with combination of two-three real lights with one shadow casting light.
