Home › Forums › Graphics / 3ds Max › Exclude Objects from Lights in 3ds Max
- This topic has 11 replies, 2 voices, and was last updated 7 years ago by
Mikhail Luzyanin.
2018-03-05 at 8:30 am #2636
3dmdlb
CustomerHello Soft8Soft-Team,
when i exclude the Button-Planes/Objects from the Lights in my Max-Scene this seems to be not working in my html-File later. In the html-file the Lights affect the Planes again. Is there any way to do that? If this Function cannot be exported from Max, maybe it can be done later in Puzzles?Regards Jochen
2018-03-05 at 8:58 am #2639Mikhail Luzyanin
StaffHello Soft8Soft-Team,
when i exclude the Button-Planes/Objects from the Lights in my Max-Scene this seems to be not working in my html-File later. In the html-file the Lights affect the Planes again. Is there any way to do that? If this Function cannot be exported from Max, maybe it can be done later in Puzzles?There’s no way to exclude objects from lighting in current version of the engine, but we already added this feature in dev version and will release it during next week.
2018-03-05 at 9:08 am #26423dmdlb
CustomerHello Mikhail,
that’s great, thanks for the info!2018-03-14 at 8:20 am #28203dmdlb
CustomerHi,
sorry if i’m a little unpatient, but is there already a release date of the new Verge3D-Version for Max? With the “exclude objects from lighting”-function, which is very important for me.Regards Jochen
2018-03-14 at 3:33 pm #2867Mikhail Luzyanin
StaffHi,
Hi, the last release of the Verge3D for 3ds max is on the way, but unfortunaly there will be no feature that you want because I think I missunderstud your request. I thought it means excluding from shadowing not from overall lighting. To exclude object from shadow casting you need to remove the Cast|Recieve shadows checkboxes in object’s properties. But excluding an oblect from lights influens is very difficult tusk, I don’t think that it will be possible to support it in near future. Sorry for that.
2018-03-14 at 4:02 pm #28763dmdlb
thanks for your reply.
The problem is, that in my gltf-file, when i rotate or move, the lights will affect the lighting/shadows of buttons i have in the foreground.
You also have that effect in your recliner-demo-scene. When you rotate or move the shadows/light effects the material-balls.
Deactivate cast/receive shadows in max has no effect.
Any idea or workflow to solve this?2018-03-14 at 4:47 pm #2887Mikhail Luzyanin
StaffDeactivate cast/receive shadows in max has no effect.
It’s available in last release that is out an hour ago. Try it.
For now only way to get a shadeless version of the material is to set Self-Illumination of the material to some value higher than 0, but not so heigh. We try to find a working workflow for this, becuse there’s no good solution in 3ds max, may be we add a Shadeless checkbox in next release. Excluding object from the lighting won’t help because the object will be absolutely dark.
2018-03-14 at 5:02 pm #28893dmdlb
CustomerOk sounds good, i will install the new version and try it.
If excluding objects from lights is working, then it can be a solution. I can exclude the buttons from the main lights and create some extra lights linked to the cam only for the buttons.
As an idea for later V3D-versions, it might be helpfull to create buttons with puzzles (for people like me without coding-abilities).2018-03-15 at 7:19 am #29003dmdlb
CustomerI tried the new Version, but the Problem cannot be solved with deactivating cast/receive shadows. It’s only working if you adjust the cam in a way that it always stay behind the (spot-)lights.
Is there any way to create buttons or insert jpg-pics with puzzles/without coding?2018-03-15 at 8:24 am #2909Mikhail Luzyanin
StaffI tried the new Version, but the Problem cannot be solved with deactivating cast/receive shadows. It’s only working if you adjust the cam in a way that it always stay behind the (spot-)lights.
I think I was not clear enough, I said exactly that it won’t help. I also suggested you to use Self-Illumination instead of excluding object from lighing.
Yes, we thought about such functionality and already moving to it’s implementation.
2018-03-15 at 8:39 am #29133dmdlb
CustomerHi Mikhail,
i understand your suggestion with using self illumination and the deactivating shadows. But when the cam is in the same angel as the light, the light hits the button-plane with “full force” and then there is an overexposure. So also with self-illumination the lights will have an effect.
But as i said, i found an working solution: Use Spotlights and stay behind behind them with the cam. And activate Self-illumination in the Button-Material, otherwise they stay dark ;-).
It would be fantastic if there is a “Button-Function” in Puzzles in the Future!2018-03-15 at 8:59 am #2916Mikhail Luzyanin
StaffUse Spotlights and stay behind behind them with the cam. And activate Self-illumination in the Button-Material, otherwise they stay dark ;-).
It would be fantastic if there is a “Button-Function” in Puzzles in the Future!Ok, we will think about implementation of both workflow.
