Exclude lights from reflections
Home Forums Graphics / Blender Exclude lights from reflections
  • #47034
    gregor1
    Is it possible to exclude the visibility of light sources from reflecting in a glossy surface? They are not visible in the scene so I don’t want them visible in reflective surfaces, especially where I’m using a reflection plane or a cube map. I can eliminate them in Blender but they are persistent in Verge.
    #47035
    I ran into this issue as well on one of my projects. https://webgl.r66dapps.com/escapev1/. I had lots of lights initially.
    Unfortunately, if you have lights in your blender scene you will have lights in your reflections verge3d scene.
    In order to control what is reflected in your reflection plan and cube map you will need to modify your lighting paradigm. Take a look at the scooter demo that comes with verge3d.
    The overall idea is to light your scene with and HDR environment…then have a small environmental sphere or object that will reflect in your scene. This can be a white sphere, or background image…. basically a 3d 360 cyc wall. Your light probes will only pickup the reflection of the cyc wall and you wont have any environmental reflections from the HDR. This method completely eliminates the need for lights.
    Note: if you need to have a specific light reflect you can setup a emissive object to represent your light and it will show up in a reflection without being a light.
    Overall lights are just bad for Verge3d and WebGL in general. They make the scene extremely heavy and slow the performance so avoid them at all costs if possible.
    Note…light probes are costly too with respect to performance and because they are cubic or planar they dont always do a great job at reflections but they get us by until something better shows up.
    #47047
    gregor1
    Thanks – you confirmed what I suspected. I find lights to be manageable as long as I turn shadows off. Better start baking!
    It does seem like an obvious opportunity for improvement though. I don’t know why anyone would want big white spots showing in their reflections.
    Nice escape room by the way!
    Greg
