Tagged: container, Cursor, eventlistener, events, mousemove
- This topic has 4 replies, 2 voices, and was last updated 1 year, 11 months ago by
Webenart.
2023-04-28 at 5:22 pm #63325
Webenart
Customerhi,
i set that puzzle for the mouse to follow the cursor, it works, but it does only inside the v3d-container, i need the mouse event to happen on the whole browser,. not just on the verge3d container.
i tried:
“document”,
“window”.
and “body”it supposes to work with document option, also tried the “in parent doc” but no difference. it works only when the cursor is inside the v3d-container.
I implement the verge3d project by adding to the container i need the id “v3d-container” on a wordpress website . No iframe, no index file etc.
regards
Webenart | Creative Websites
webenart.com2023-04-28 at 8:33 pm #63326kdv
Participantit works, but it does only inside the v3d-container
that’s because only
v3d-container
has an event listener to read the screen coordinates.
read hear https://www.soft8soft.com/topic/move-head-animation-by-moving-the-mouse-2/Puzzles and JS coding. Fast and expensive.
2023-04-28 at 9:11 pm #63327Webenart
CustomerHi,
So i tried it,
const xNorm = event.offsetX / event.target.clientWidth;
const yNorm = event.offsetY / event.target.clientHeight;
VARS.pGlob.screenCoords.x = xNorm * 2 – 1;
VARS.pGlob.screenCoords.y = -yNorm * 2 + 1;indeed i get movement outside of v3d-container, that’s a good start, but when the mouse got from the v3d-container to the parent container the movement of the 3d object it is way larger than inside the container, and its sudden, it is noticable that you are getting out of the container with the cursor, bcs the object “jumps” to a different location, like the center changes.
I tried a few different parent containers for the possibility there is an issue with the one i chose, still the same.
regards
webenart.com2023-04-28 at 9:20 pm #63328kdv
ParticipantWell, now that’s your quest. You need to figure out how to block the event listener in
v3d-container
and read the screen coordinates from the parent window only…the object “jumps” to a different location, like the center changes.
that’s because the center is really changed…
2023-04-28 at 9:40 pm #63329Webenart
CustomerUnfortunately i have not the skills to do that, thanks for the help anyway :)
webenart.com -
