Essential Material Pack
Home Forums Graphics / Blender Essential Material Pack
  • #64446
    David Duperron
    Hi!
    I’ve just purchased the material pack to speed up our material setup process, but I am facinf some issues…
    For example the oil_painted_wall material does not look the same at all in the Blender 3D preview (Eevee, which is very close to what I get when I click on the example provided on your product page ) and the sneak peak export. I use the example file to test it…
    What am I doing wrong? Are there some specific parameters to check before the export? is the sneak peak limited in some way??
    in the Blender UI:
    Sneak Peak export:
    #64449
    Strange behaviour, can you give more information about the scene you export or may be attach the scene.
    #64493
    I am getting the same result with the same material.
    Using Blender 3.5.1 V3D 4.3.1.
    Default scene – delete cube.
    Add UV sphere
    Get the exact result as shown.
    To achieve the results you see in the blender viewport you will need to remove the Gamma node shown here.
    There seem to be some issues with many of the materials (cloth specifically) not being visually the same as they have been in the past. Probably since many of the nodes used have been updated since the material pack was released.
    • This reply was modified 1 year, 9 months ago by xeon.
    #64578
    David Duperron
    Hi Mikhail,
    I use the exact example scene as it comes with the bundle (there is one blender file per material). No tweaking at all.
    Thanks Xeon, I’ll try your solution!
    Cheers
    David
    #64579
    Hi all, thanks for sharing this!
    Unfortunately, it has nothing to do with the Gamma node (just a coincidence). A workaround would be to set the alpha mode to “Straight” (never mind that it’s actually disabled).
    Meanwhile, the fix is coming in the upcoming preview build of Verge3D.
    X | FB | LinkedIn
    #64785
    Fixed!
    X | FB | LinkedIn
