Error when trying to enter VR mode
Home Forums Puzzles Error when trying to enter VR mode
  • #19817
    vrsilly
    Please help! I cannot enter VR mode.
    I have tried different puzzle logic involving VR mode including with and without boolean variable, snap and parent camera to empty, no variable logic, and phone browser, pc browser, and oculus quest. xmasVR and industrialrobotVR work fine on all browsers.
    I keep getting Console Error (see error.jpg attached) –
    v3d.js:1 Uncaught TypeError: Cannot read property ‘requestSession’ of undefined
    at av.initWebXR (v3d.js:1)
    at enterVRMode (visual_logic.js:602)
    at HTMLDivElement.<anonymous> (visual_logic.js:660)
    initWebXR @ v3d.js:1
    enterVRMode @ visual_logic.js:602
    (anonymous) @ visual_logic.js:660
    project and files are hosted at http://devusol.com/vr_help/kitchenScene/index1.html
    Any help is greatly appreciated.
    #19826
    it says your browser does not support WebXR. You need to enable it manually or use an origin trial generated for your domain devusol.com. See more info in the User Manual.
    X | FB | LinkedIn
    #19845
    vrsilly
    Thank you for a quick reply. I have replaced origin trials meta tag in the html file with our own token generated for the site. (see .html file attached). The error still seems to persist. Is there perhaps another place where I must implement this token for it to work properly? Thank you.
    #19848
    vrsilly
    attached html with origin-trial token
    #19851
    I see. Will this issue remain if you enable WebXR manually using chrome://flags ?
    X | FB | LinkedIn
    #19866
    vrsilly
    Thank you for looking at this. Unfortunately even when all flags enabled, the problem persists. I don’t understand, xmasVR and industrialRobotVR projects work just fine on all platforms, even when hosted from our site. https://devusol.com/vr_help/xmas_vr/xmas_vr.html
    #19875
    vrsilly
    It appears that when I use IE 11 compatibility checkbox and build the scene inside the given blender file, the VR puzzles work.
    #19883
    really strange issue! You can share the link to the project archive and we’ll try to look into this.
    X | FB | LinkedIn
