equivalent of app.controls.tween easing
Home Forums Programming equivalent of app.controls.tween easing
  • #33509
    thomasup
    so we are moving a camera via app.controls.tween (copied from tweenCamera puzzle)
    but we want to match the camera movement with another animation, that runs at the same time, with the same easing applied.
    from tweenjs, both quadInOut and sineInOut seem to be a close match, but are still a bit different, and make it look a bit odd, because the camera temporarily leaps ahead / lacks behind.
    so it would be helpful to know what the easing function used in app.controls.tween is, so we can match it with our own animation.
    #33524
    in that puzzle, the camera is tweened by using linear or spherical interpolation.
    Anyway, you can possibly use this puzzle for both the camera tweening and your own animation.
    #33611
    app.controls.tween uses the MathUtils.smootherstep function for tweening.
    #33617
    thomasup
    thank you for the answer, but we looked into the puzzle but no option was fully synchronized.
    after quite some digging in the minified v3d code i found out that
    v3d.MathUtils.smootherstep
    is applied to the linear camera transition progress.
    this helped me solve the issue, now both movements are in sync, by applying the smootherstep to the secondary animation too.
    Edit: it is now silky smoooth. nice!
    #33622
    thomasup
    ah i found it out in the meantine, but thank you, Ivan!
    #33666
    :good:
