Environment through windows in interior scene
Home Forums General Questions Environment through windows in interior scene
  • #54235
    nsansomw
    Hi all, I am creating an interior scene which is in a high rise building and I am wondering what is the best way to create a background through the windows.
    I have not found any good high rise building environment maps. I am after suggestions, is there a better way than using a big environment map, maybe a texture or low poly models, combination?
    Please see the attached. At the moment it looks like it is in a field. I have also baked all the lighting inside.
    Thanks.
    #54244
    Look at global illumination demo, there’s a half sphere outside the window that works good.
    #54252
    nsansomw
    Thank you Mikhail, I will give this ago. I noticed the image has a fisheye effect on it. Is this necessary? or could I just use a normal image?
