Enter text
Home Forums Puzzles Enter text
  • #6640
    rezman
    I’m trying a simple demo of dynamic text where the user enters text and the text object changes. This works, but the camera is selected after the text updates and moving the mouse orbits the text. Is there a way to simply update the text without the camera being selected?
    #6643
    You can add another camera in Blender and set its controls type to “No controls”. Then you can use the set active camera puzzle to switch between your main camera and the static camera in order to disable orbiting when the user enters text.
    #6661
    rezman
    Ah! Perfect, thanks Yuri.
    #6662
    rezman
    Quick follow up question. Is it possible to change the font via a click. Such as Puzzles or coding?
    Ie: Enter text. Choose font?
    #6663
    You can use custom fonts and update text objects on the fly. Here is more info https://www.soft8soft.com/verge3d-2-2-for-blender-released/
    I guess you can swap text objects with different fonts applied to them via Puzzles.
    #6664
    rezman
    That would work. Thanks Yuri!
