enabling SSAA ruins annotations sticking to an object
Home Forums General Questions enabling SSAA ruins annotations sticking to an object
  • #54144
    With SSAA enabled an annotation doesn’t move with its parent object. Is it normal or can be fixed?
    https://v3d.net/9cj
    #54166
    Yes, this is a limitation of SSAA. Instead, you can try increasing the resolution with set screen scale
    #54340
    NaxosCG
    https://v3d.net/9cj
    Hi, i have a candid question about SSAA : how do you activate it ?
    For now i’m using the puzzle : “disable rendering with AntiAlisaing”.
    It is quite heavy : i have to set a variable each time the user is moving camera / changing an option, and for each frame check this variable and enable or disable+AA rendering.
    Maybe SSAA would let us have AA even when moving…
    Thanks.
    #54342
    But keep in mind that it will significantly encrease the amount of rendered tris and CPU/GPU load. In the example above it doesn’t matter, the model is rather simple, but with large models, having over 500k tris, it can be a real problem with perfomance )))
    Yes, it will if you don’t have Eevee AO enabled…
    #54344
    NaxosCG
    I’m a ashamed 3dsmax user ;-)
    I guess that if i use AO in the export settings, SSAA may not work : i’ll test that.
    Many thanks, seams simple, but ok, i’m a 3D guy, not coder…
    Bests
