I tried to make a website using verge3d, however when I embed my app into my website builder (Wix), it stays stuck on the loading screen. This issue started when I changed the verge3d default loading screen to a custom one. Specifically I added the html/css/javascript code for the loading screen into the respective project files. I need help getting the app to run when embedded, I think the issue might be that I need to add some code on top of the html/css/javascript.
The website has worked after embedding on Wix before, so the project should be fairly straight-forward but I don’t have the technical knowledge to fix the current problem.
I have confirmed the website is stuck infinitely loading and does not require optimization to fix this issue. Please feel free to ask any questions for any specifics you may need.
