(Eevee) AO ghosting in Verge3D 3.9 pre 1 almost solved!
Home Forums Bug Reports and Feature Requests (Eevee) AO ghosting in Verge3D 3.9 pre 1 almost solved!
  • #46912
    illussimo
    The AO ghosting of invisible objects issue is (almost) solved in 3.9 pre 1! :good:
    However, there is still a slight AO ghosting visible of completely transparent objects even if object visibility is keyed in the timeline.
    Only if the object is hidden using puzzles the AO ghosting fully disappears.
    I tried to hide an object if it is on a certain key-frame with puzzles but that didn’t work. It would also be a hassle to implement in complex animations.
    Hopefully, you will find a way to make Keyed Object Visibility export to Verge3D or make the AO for transparent objects completely invisible.
    Thanks, :bye:
    #47160
    Thanks for reporting this bug! It will be fixed in the next pre-release version.
