Home › Forums › General Questions › Edge issue
- This topic has 4 replies, 2 voices, and was last updated 8 years, 1 month ago by
NewFake.
2018-08-05 at 12:01 am #6168
NewFake
CustomerHello!
when displaying an app using the htmlviewer in MS Edge the console tells me the following. Please check what happens as something is looking for that weird version of the logic file:
visual_logic.jsvisual_logic.jsMS Edge’s console:
[object Error]: {description: “Unable to load the logic file: ‘visual_logic.jsvisual_logic.js’.”, message: “Unable to load the logic file: ‘visual_logic.jsvisual_logic.js’.”, name: “LogicLoadError”, stack: “LogicLoadError: Unable to load the logic file: ‘visual_logic.jsvisual_logic.js’. at _createLogicLoadError (https://www.litvine-georges.com/3d/cadavreexquis/v3d.js:1:821944) at Anonymous function (https://www.litvine-georges.com/3d/cadavreexquis/v3d.js:1:822392)”}v3d.WebGLProgram: gl.getProgramInfoLog()
C:\fakepath(233,25-83): warning X3571: pow(f, e) will not work for negative f, use abs(f) or conditionally handle negative values if you expect themv3d.js (1,378250)
v3d.js (1,378250)
v3d.CSS3DRenderer 2.5.0
CSS3DRenderer.js (41,5)v3d.WebGLProgram: gl.getProgramInfoLog()
C:\fakepath(75,25-83): warning X3571: pow(f, e) will not work for negative f, use abs(f) or conditionally handle negative values if you expect themv3d.js (1,378250)
HTTP404: RESSOURCE MANQUANTE. Le serveur n’a trouvé aucune correspondance pour l’URI demandé (Uniform Resource Identifier).
GET – https://www.litvine-georges.com/3d/cadavreexquis/visual_logic.jsvisual_logic.js___________________________________________________
FireFox’s console:
Successfully compiled asm.js code (loaded from cache in 28ms) v3d.js
Verge3D 2.5.0 v3d.js:1:397123
LogicLoadError: “Unable to load the logic file: ‘visual_logic.jsvisual_logic.js’.”
_createLogicLoadErrorhttps://www.litvine-georges.com/3d/cadavreexquis/v3d.js:1:821950_getLogicPromisehttps://www.litvine-georges.com/3d/cadavreexquis/v3d.js:1:822394 v3d.js:1:821727
v3d.WebGLProgram: gl.getProgramInfoLog() C:\fakepath(233,25-100): warning X3571: pow(f, e) will not work for negative f, use abs(f) or conditionally handle negative values if you expect themv3d.js:1:378470
v3d.CSS3DRenderer 2.5.0 CSS3DRenderer.js:41:5
v3d.WebGLProgram: gl.getProgramInfoLog() C:\fakepath(75,25-100): warning X3571: pow(f, e) will not work for negative f, use abs(f) or conditionally handle negative values if you expect themv3d.js:1:378470
Échec du chargement pour l’élément <script> dont la source est « https://www.litvine-georges.com/3d/cadavreexquis/visual_logic.jsvisual_logic.js ».Please, note that the app works fine in FireFox, however not in Edge.
As I told you, I don’t want to bother with the htmlviewer, however I think that this post might help you to fix things in the v3d.js file.NewFake :)
2018-08-06 at 9:22 am #6177
Yuri KovelenovStaff2018-08-12 at 10:47 am #6349NewFake
CustomerHi!
At first, please, note that I promised I would not be much too demanding about htmlmixer; therefore what I write here are tracks to help, to feedback; I’m not demanding whatsoever
I updated the app to 2.6.
The whole app doesn’t work at all, the page that is “iframed called” is much too big. I don’t care.But what could be of interest for you is that V3d.js and v3d.CSS3DRenderer are still looking for the weird *.js file: visual_logic.jsvisual_logic.js
even through Verge3D 2.6.0:
and
Échec du chargement pour l’élément (which means “can’t load”) <script> dont la source est « https://www.litvine-georges.com/3d/cadavreexquis-2.6/visual_logic.jsvisual_logic.js ».Also useful I guess:
d.AppPuzzles has been deprecated. Use v3d.PuzzlesLoader insteadAlso in the block v3d.CSS3DRenderer 2.6.0:
v3d.js:1:392763
Also, please, check what the console says against the patched htmlmixer app you uploaded here for me:
https://www.litvine-georges.com/3d/htmlmixer/htmlmixer.html
______________________________I’m going to let the updated version to 2.6 for a few days there, for the feedback:
https://www.litvine-georges.com/3d/cadavreexquis-2.6/cadavreexquis.phpThe one that works quite well, but in Edge…:
https://www.litvine-georges.com/3d/cadavreexquis/cadavreexquis.php
______________________________Hope that helps, and, please, can you over comment?
NewFake :)
2018-08-13 at 1:30 pm #6370
Yuri KovelenovStaffHi,
It looks like we forgot to update the HTML Mixer app to version 2.6. There was some significant refactoring in the Player code. I’m attaching the updated app, thanks for the feedback!
2018-08-13 at 3:31 pm #6391NewFake
CustomerHi!
Most welcome you are :) Could you please apply the patch that makes the iframe follow the animation of the carrying object?
NewFake :)
