Dynamic “Material Outputs”?
Home Forums Graphics / Blender Dynamic “Material Outputs”?
  • #29456
    GLiFTeK
    I wouldn’t think this is possible, but might as well ask…
    Blender lets you have more than one material output node. I make a few networks to test things out, the material output that’s clicked last is active and is the one blender/Verge uses.
    Is there a way to have more than one be available to be switched between using js?
    Thanks
    #29711
    Yes, only the active output is taken into account when the engine compiles a material. Everything that’s not connected to that output is removed and not processed.
    No, you can only switch between different materials.
