Home › Forums › General Questions › Drawing free lines in 3D + Images as light projection?
- This topic has 6 replies, 4 voices, and was last updated 2 years, 9 months ago by
kdv.
2023-12-13 at 9:50 am #69136
alissa
ParticipantHey I have 2 questions and I hope someone can help me!
Is there a way to draw lines from the curser inside the 3D space? Like drawing free lines inside the scene in the application.
Is it possible to use an image/video for light projection? Kind of like a beamer/projector? Is it supported by verge3d?
Thank you for any help!
2023-12-14 at 12:39 am #69150
xeonCustomerDrawing lines… it depends on what you really mean. You can create drawing tools over the canvas. But if want to show a line from the pointer to an object in 3d space … it’s possible but like draw tool … not pretty.
Light projection is not supported. However there are lots of things you can do to fake it if your scene supports it creatively.
Tutorials - https://www.xeons3dlab.com2023-12-14 at 5:06 am #69151kdv
ParticipantIs there a way to draw lines from the curser inside the 3D space?
Possible. Just provide two points in the 3D space (you wil have to use a raycaster for that purpose) and this puzzles will draw a line.
2023-12-14 at 8:41 am #69158alissa
ParticipantOkay thank you! I meant drawing free lines, not straight but like drawing with a pen into 3d space.
2023-12-14 at 8:43 am #69161kdv
ParticipantOk. In this case the answer is short and simple: No.
2023-12-27 at 8:10 am #69381
visualizerParticipantI was also searching for any possibility to show the line getting drawn in 3D space with controlled animation speed. The progressing line…it may have turn & loops !
As Alissa saying,
I feel there two wats mainly
A) One the user facility to draw from point A to B
B) Second is animated line getting drawn from point A to BIntention for B is to use in schematic diagrams to show the flow
2023-12-27 at 10:00 am #69384kdv
ParticipantIt’s quite possible to draw lines on meshes with UVs
but hardly possible to do it in the pure 3D space. coordinates will be undefined.Puzzles and JS coding. Fast and expensive.
