Home › Forums › Programming › draw text to canvas
- This topic has 13 replies, 3 voices, and was last updated 6 years, 1 month ago by
kubuz.
2020-08-22 at 9:28 pm #31863
kubuzCustomerHi,
Can someone please explain a bit more in depth how to draw text on a canvas.
In the manual its just one line, i am a bit confused here.
Is there a puzzle available for this ?Thanks.
Best Dennis2020-08-23 at 6:20 am #31870
GLiFTeKCustomerHi, Can someone please explain a bit more in depth how to draw text on a canvas. In the manual its just one line, i am a bit confused here. Is there a puzzle available for this ?
Thanks. Best DennisYou can use “fillText“.
You can also use the “texture from text puzzle” in the material portion of the menu.
plz share Discord link & on your signature!2020-08-23 at 11:20 am #31881
GLiFTeKCustomerhere kubuz…
use this.. (in either runCode, call JS externalInterface, OR the new script text puzzles…
(just need to arrange them in execution accordingly)var canvasTex = v3d.puzzles.canvasTextures['my_canvas']; var canvas = canvasTex.image; var ctx = canvas.getContext("2d"); ctx.font = "30px Arial"; ctx.fillText("Hello World", 10, 50); canvasTex.needsUpdate = true;with the according canvas replacement puzzles seen in the user manual setup here..
plz share Discord link & on your signature!2020-08-28 at 9:34 pm #32139
kubuzCustomerHi Guys,
@Gliftek, many thanks for your solution earlier. You helped me a lot.
By the time I figured this out myself, I would be grey.
Thanks.So I managed to draw text on a canvas. Struggled a bit with the custom font part. And then I noticed there was a piece of puzzle for that.
Now I have some strange behaviour.
If I preview the app local, it works like a charm. But, when i upload it to the Verge CDN, it doesn’t load the font.
Does anyone have a clue ?
2020-08-29 at 4:58 am #32145
Yuri KovelenovStaff2020-08-29 at 6:09 am #32149
kubuzCustomerIt must be some cache issue. Thanks a lot!
2020-08-29 at 3:59 pm #32158
Yuri KovelenovStaff2020-08-30 at 12:29 pm #32199
Looks like every milestone has some issues
Now, i have my font in place, but for some odd reason it doesnt update after changing the text….First i tought, I need to update in the script. like on How-to-update-things.html but that doesn’t change anything. The string is passed to the script correct.
Does anyone have a clue what i miss ? It must be something simple.
function prepareExternalInterface(app) { app.ExternalInterface.myJSFunction = function(myText) { //window.addEventListener("load", function(){ var canvasTxt = window.canvasTxt.default; var canvasTex = v3d.puzzles.canvasTextures['my_canvas']; var canvas = canvasTex.image; var ctx = canvas.getContext("2d"); var txt = myText; console.log(txt); ctx.clearRect(0, 0, canvas.width, canvas.height); ctx.restore(); canvasTxt.fontSize = 80; ctx.fillStyle = '#0234d6' canvasTxt.font = 'BacktoBlack' canvasTxt.drawText(ctx,txt,100,100,800,800); ctx.save(); ctx.needsUpdate = true; //canvasTxt.drawText(ctx,txt,x,y,width,height); //}); }; };2020-08-30 at 3:33 pm #32202
Yuri KovelenovStaff2020-08-30 at 4:23 pm #32203
kubuzCustomerHi Yuri,
Its just a placholder with the parameters as a comments. 2 Lines up we have the one that executes.2020-08-30 at 4:33 pm #32204
Yuri KovelenovStaffGot it! May be the issue lies in using canvasTxt rather than ctx (which is associated with the material).
Also can you try the following method which looks simpler?
2020-08-31 at 9:11 am #32234
Thanks a lot pal, sometimes the answer is so plain simple that I can’t see it anymore. I use the Canvas TXT library to center and multiline texts.
I keep this tread updated for later reference.Thanks again. You guys are awesome.
2020-08-31 at 10:40 am #32240
GLiFTeKCustomerdid you include a “load font” puzzle in your initialization tab in your puzzles editor for your specific font?
doesn’t look like you’re using the “texture from text” puzzle, which needs that to function, but maybe referencing the font specifically might help with the issue.
EDIT: oops.. look like you got it!
plz share Discord link & on your signature!2020-08-31 at 12:18 pm #32242
kubuzCustomerdid you include a “load font” puzzle in your initialization tab in your puzzles editor for your specific font?
Jeah, i did. I am Beginning to understand how the whole canvas stuff works.
Got a nice big project for it in the near future -
