Dragging on circular surface instead of rectangle ??
Home Forums General Questions Dragging on circular surface instead of rectangle ??
  • #29235
    yasse
    Hello dears, I Hope you doing good.
    Please I was wondering if we can achieve the possibility to drag an object within a specific cylinder or a circular area.
    the drag and drop can make the object be dragged freely on all space, and there is constraint limitation but it works only as a rectangle (with min and max value) (like red rectangle on the picture attached)
    i will be so thankful if someone tried a solution for similar case ?
    thank you so much.
    #30325
    you can possibly try implementing this with the physics puzzles:
    https://www.soft8soft.com/docs/manual/en/puzzles/Physics.html
