Draggble object to hide several objects
Home Forums Puzzles Draggble object to hide several objects
  • #25885
    vch687
    Hello!
    I’ve got a draggble object (“controller”). I need to create an effect: when I drag it down (from point A to point B in axis Z, for example) another object (say “object_1) would hide. Then I keep dragging down the controller (from point B to C) another object would hide (“object_2), and so on. However, if I drag the controller up (from pont C to B and then from B to A) the objects would show (the object_2 at first, and then the object_1).
    Can I create this effect with puzzles? Thank you.
    #25897
    Here you go.
    #25946
    vch687
    Thanks a lot! It really helped!
    Now I’m wondering if the same can be done to affect images o bottons from webflow.
    I’m trying to make desappear some images located on the website by dragging my controller located in Verge3D, but without success :scratch: . I understande that the interaction with html elements is different, and somehow it works in the “Industrial Robot” exemple. And I don’t understand how. When you click on any component of the robot (except the base), the right buttons show; when you click on the base, they hide. Aand the tutorial doesn’t explain how it’s made.
    Thank you for your help. :)
    #25956
    Yes, this can be made.
    Instead of hiding of the object you can change a visibility of the buttonl or change a background image HTML puzzle. Just replace them with that puzzles.
