Download Generated Normal Map
Home Forums Puzzles Download Generated Normal Map
  • #25608
    rreyes3d
    Hello,
    im trying to combine a normal map with another generated using puzzles, however it doesn’t behaves as i want.
    so i would like to download the generated normal map to be able to use it in blender and try to fix it using nodes inside blender.
    I attached an image showing the puzzles that I’m trying to use to download it
    normal-map
    #25610
    at the moment, the download puzzle won’t work properly with the generate normal map puzzle, because normal map creation takes some time, while the download puzzle starts downloading immediately.
    To work around this problem, save your normal map in a variable, and then download it using that variable after 1 second for example.
