Disable Verge3D WordPress Plugin Updates and Log Emails from send_form.php?
Home Forums General Questions Disable Verge3D WordPress Plugin Updates and Log Emails from send_form.php?
  • #79097
    Pandern
    Is there a way to completely disable updates for the Verge3D WordPress plugin to prevent overwriting custom files?
    Also, is it possible to log emails sent via send_form.php for debugging or tracking?
    Thanks!
    #79098
    Hi Pandern,
    You can disable auto-updates for Verge3D using the standard WordPress feature located on the “Plugins” page in WP admin UI.
    Regarding email logs, set the DEBUG_WP_MAIL constant located in the utils.php file to true. The emails will appear in the “main-debug” directory inside the Verge3D upload directory, e.g. WP_INSTALLATION_DIR/wp-content/uploads/verge3d
    X | FB | LinkedIn
    #79114
    Pandern
    Thank you
    The auto-updates were, and are, disabled, but the plugin still updated to 4.8.0. Is there a sure way to prevent this from happening again?
    edit: I checked on other instalments i have of the plugin and they’ve not been updated. Only on this one site. Have to check with the webmaster there again.
    DEBUG_WP_MAIL works as intended, but I’ve edited send_form.php to send two emails (to vendor and customer). Only the last one appears in the mail-debug folder, so it’s not quite a complete log of outgoing emails. It’s not a big issue, but I thought I’d mention it.
    Thanks again!
    • This reply was modified 4 months, 3 weeks ago by Pandern.
    #79123
    Hope you figure out why updating is performed. Regarding DEBUG_WP_MAIL, unfortunately yes, this feature works only for the last email. :unsure:
    X | FB | LinkedIn
