Disable / Enable Rendering with Anti-aliasing on causes problems
Home Forums Puzzles Disable / Enable Rendering with Anti-aliasing on causes problems
  • #74392
    viap
    Hi!
    When I use Disable Rendering with Anti-aliasing on, following problems appears:
    – entering full screen causes the application to freeze
    – opening JPG file and opening webpage (both in new tab) causes the application to freeze
    With Anti-aliasing turned off, everything works perfectly, but the problem is that some objects (which are programmatically hidden by the application) are now visible for some time after the application starts. Now I solved it by hiding them behind the main object, but in general it’s a problem.
    #74410
    Strange thing! The app should work correctly when changing canvas dimensions, could you please provide some example that reproduces this behavior?
    Regarding hidden objects, why not hide them in the modelling software? This way there won’t be any glitches on startup.
