Disable/Enable HTML element clicking
Home Forums General Questions Disable/Enable HTML element clicking
  • #32949
    KurtGR
    I’m nearing the end of my project, just a couple more little features to work out – one I’m currently stuck with, is a way to make a puzzle that triggers a button element to be unclickable until the animation is finished, I tried adding a time puzzle for 3 seconds and setting the elements attribute of “disabled” to “true” – but honestly I have no idea what I’m doing when it comes to HTML/CSS – is there a simple way to achieve this?
    http://labs.greenretreats.co.uk/HTH_Verge3D/ – if you check the project out here, and basically spam-click the water button, you’ll see it’s desirable to make the button unclickable until the animation has finished.
    Other than that….is there a simple way to add a glow/highlight effect to the buttons that are selected on the left hand side?
    Thanks a lot, loving the software so far.
    Kurt.
    #32957
    You can use puzzle is plating with IF operand to control if animation not playing then run all inside Click puzzle, but if it’s playing do nothing by just putting all puzzles inside this If operand.
    #32973
    KurtGR
    Cool it worked, thanks!
    #32974
    :good:
