Different Outlining Color Effect
Home Forums General Questions Different Outlining Color Effect
  • #77991
    ATGmedialab
    Hello Verge3D Community,
    I’m currently trying to create an outline effect on diferent objects and each with diferent outlining color. At the moment, I can only select a single outline color through the export settings.
    Can we add diferent colors to the outlining effect for specific objects?
    Is there a way to achieve this via JavaScript or any other method?
    Thank you!
    • This topic was modified 5 months, 2 weeks ago by ATGmedialab.
    #77996
    Hi ATGmedialab,
    Unfortunately only 1 global color can be used for outlining. A way to overcome this limitation is to highlight the individual object with emission color.
    #77997
    create several outline passes with different colors. but this will probably have a huge impact on the overall performance.
    #78029
    ATGmedialab
    I see, I will try these other methods.
    Thank you both for the information and options available.
    Regards.
    #78429
    muhuzhongxun
    JS can change the outlinning color
    let vEdgeColor = app.postprocessing.outlinePass.visibleEdgeColor;
    let hEdgeColor = app.postprocessing.outlinePass.hiddenEdgeColor;
    vEdgeColor.x = 1;
    vEdgeColor.y = 0.216;
    vEdgeColor.z = 0;
    vEdgeColor.w = 1;
    hEdgeColor.x = 0;
    hEdgeColor.y = 0;
    hEdgeColor.z = 0;
    hEdgeColor.w = 1;
    #78431
    Indeed… It’s possible to change the color depending on what object has been chosen. But it won’t work with two or more different objects outlined simultaneously.
