[Dictionaries] Changing property order
Home › Forums › Puzzles › [Dictionaries] Changing property order
  • #34370
    matthew
    Hey guys,
    I am working on a stackable product configurator, built with differently sized segments. I am basing it on a premise that whenever I delete a segment that is not the last in the stack (eg. right in the middle), I need to move every object above the deleted object one level below. I used a dictionary to setup the stack, that goes like this:
    Artboard-1
    Here’s an example of a stack order created by random clicks (objects inside are cloned from within the scene):
    Artboard-1-copy
    Now after I delete an object in level 3 which in hereby example is “Blue3” I want all the objects in higher levels to move down one level, so now the order would be: { Level_0: “Yellow2”, Level_1: “Yellow3”, Level_2: “Blue2″, Level_3:”Yellow_4”, Level_4: “Yellow_5”, Level_5: “Blue4”, Level_6: null }
    How do I achieve this?
    #34404
    matthew
    Hello, did anyone come up with an idea?
    #34452
    the order in a Dictionary (JavaScript’s Object type) is not guaranteed and cannot be controlled. You might use a List (JavaScript’s Array type) instead which allows for inserting items in desired positions.
